1 - 16 of 16 Posts
I have been using Castrol GTLMA brake fluid for as long as I can remember. I sometimes have a hard time finding it on the shelves.
So when I was in my local Kawasaki dealership I bought 2 bottles. I must have been in a hurry because I didn't look at the label
very carefully because I was so glad to find Castrol GTLMA brake fluid. This morning I noticed that the label said synthetic.
Oh no I thought this stuff has silicone in it. I am thinking and hoping that silicone is only DOT 5. I can't even find the msds data
sheet for this stuff and there is nothing on the label that says silicone.
I been running this fluid in my brakes for well over a year and just changed my clutch fluid with no ill effects.
Does anyone have any experience with this stuff or knowledge of its chemical makeup?
This is a link to what I bought:
http://www.amazon.com/Castrol-GT-LMA-Brake-Fluid/dp/B000WPB6DS
If it says Dot 3 or 4 your good to go.
Yep, just looked at the link and it says right on the container, exceeds specs for Dot 3 and 4. Good to go.
DOT 3, DOT 4, OR DOT 5.1 all work fine with each other.
It is the DOT 5 you don't want to mix with the others.
FYI to my knowledge all brake fluid is synthetic rather the label says so or not.
Wayne
I am curious to know. I installed speed bleeders and did not tighten down one of the front fittings enough. Brake fluid splattered onto my front chrome cowl and paint. But not chrome or paint was harmed. I use Napa DOT4. Does the new fluid not hurt the paint? I have used this fluid now for the second change. Speed Bleeders are a GOD SEND!
I spilled a couple drops on my top shelter about a year ago. I quickly wiped it up and noticed no damage to the paint. Not sure if it is dot 4 or the clear coat paint but it sure is nice to know.
Wayne
If the fluid is wiped up relatively soon, no damage will occur. Leave it sitting on the paint for a few minutes and witness the horror! :shock:
Wayne
This is what I have always heard. :shrug:
Probably nobody cares, but pre-DOT brake fluid was castor oil, which is a vegetable oil. Current DOT brake fluid is glycol-ether based, except DOT 5 which is silicone based.... glycol-ether based fluids by definition are synthetic.....
Wayne
IronMan
THINK MY MOM WOULD DRINK THAT STUFF :wrong::eek:4::22yikes:
Should be obvious, but ......
Does the synthetic fluid alleviate the issue of attracting moisture??
schiel1 on My Samsung 3
No, Only DOT5 silicon fluid is hydrophobic the rest is hydroscopic...
1 - 16 of 16 Posts
