OK Everyone.
I have a 2006 GW. I do not know if the CB has ever been check for calibration so I ordered a swr meter and cables from Serria Electronics. I have been reading a lot of information on and off the GL1800 board about having a good ground to the antenna.
My question is this. While I have the bike apart would this be a good time to run another ground wire from one of the two bolts that are in the trunk holding the antenna on?
If so would you run it to a good ground under the seat, since the seat will be off? Or would it be better to just go the negative from the battery.
I will make the ground using ring connectors and #12 or #10 wire and solder all connections.
Thanks in advance for your thoughs.
Larry
Larry
