1 - 2 of 2 Posts
OK, after reading of some people overtightening the front fender when reinstalling, do you just moderately hand snug the four main supports,( two brake holder, two front brace). Put them in to feel a little tension, but not tight in the sense. Added Bushtec extension. Thanks.
Tightening down the front fender
What I did to alleviate this problem is to go to thin black rubber washers under each screw and use blue Locktite.
This allows you to hand tighten them, giving them a little extra pressure with the rubber washers and then, the Locktite seals it all up.
No problems with anything coming loose!
1 - 2 of 2 Posts
