1 - 8 of 8 Posts
I discovered an Easy way to Install Rubber Drive Shaft Boots!
As you may know, it can be very difficult to Tug/Pull the ears ...on account of the very tight work space (esp on an GL1800).
If you make a small hole in each ear, and slide a Long White Zip Tie through it... then you suddenly have (6) easy-to-pull features that you can manipulate to maneuver the rubber boot into place, and even stretch it to install !
Once installed, simply push the zip ties out to remove.
Discussion Starter #4
Did something happen to the original boot ?
I removed the (GL1800) boot, in order to remove the Swing Arm (to service bearings). The boot was Ok in this case, although I've had to replace them on my 1500's.
Reactions: cycledude
IronMan
AND THE CAT KEEPS THE MICE OUT OF THE WAY ! :wink2::laugh:
If one knows how, it takes 3 secs. So easy .... so peasy !!!
If the forum took vids, I'd post it.
1 - 8 of 8 Posts
