If you insert a piece of Foam, behind the "Square Nut" on the battery terminals, then it suddenly becomes Much easier to install the terminal screw...as the nut no longer walks away, or falls out!
Leave the foam installed when done; I used sticky-back foam, like what you buy in a roll for sealing windows.
