If you swap the stock Coolant Drain for a Brass T-Ftg, and a Short downwards facing length of hose, then you get:
1) A "Sediment Sump" to passively collect debris in the system;
2) An Attachment "Inlet" via which you can suck water/coolant UP into the system, for a reverse-bleed from bottom > upwards. This method does not require any Burping of air after the fill is done. I put a temporary hose as shown, into a jug of water/coolant, and a shop vacuum atop the radiator fill, to pull fluid up/inwards.
