I installed the Electrical Connections 12V cigarette plug in the trunk today, and I wanted to share some observations. It's a plug and play 12V cigarette power port that mounts in the roof of the trunk, requiring a 1-1/8" hole be drilled in the inner lid. It has some bad reviews because it tends to pull back out of the hole when you pull out a plug, but that's easily remedied. Here's the review I left on Wingstuff.
"I installed this in the trunk, following the simple instructions. I was a little nervous cutting the hole just based on the single photo - no real measurements to go by, and more than one way to interfere with bosses in the upper trunk lid. Based on complaints of it pulling out, I bought a cheap step drill and tried a 1-1/16" hole first, but it definitely won't go into that, even when you cut a small square slot for the anti-rotating "key" on the barrel of the power plug. So I cut a 1-1/8" hole and inserted the plug. Sure enough, it pulled out much too easily. But then I snaked two zip ties through the weak "holding tabs" on the back side of the plug and cinched them tight. It can't be pulled out now, it's like it's cemented in, but it's completely reversible. I also wrapped the open back of the plug with silicone electrical tape to keep moisture and dust out of it - it's not a sealed environment back there based on all the dust I found. Lastly, I opened up the 12V splitter I bought and snipped off the LED so it won't drain my battery if I leave it plugged in. Overall a great addition to the bike with those few little (practically free) mods."
