I was leaning towards "sticky rope" and T-handle to begin with. Any place (website) where I can find a decent kit? Or any certain brand name?...
Sent from my SM-G950U using Tapatalk
^^^^ This is the best! The T-handles make getting the plug in easier than the kits with the straight handles. You should also carry a good pair of pliers to grab and remove the nail or screw that punctured the tire. I carry a pair of side cutters too. I carry a can of rubber cement instead of a small tube of cement. The rubber cement is less likely to dry out in a larger container. While it is ideal to allow the rubber cement and plug to set overnight before refilling the tire with air, as Fred H. suggested, if you get a flat while out on the road this may not be an option. I've always immediately refilled the tire with air and never had any leaks. Use plenty of rubber cement on the tool to clean out/enlarge the hole and coat the sticky rope plug with gobs of cement before inserting into the hole.Lots of high tech fancy options out there, but in most cases you can't beat the basic sticky rope and T-handle type plug kit. Get you one and practice on an old tire.
I purchased the Stop-n-Go system. I have used it once on the road and that tire lasted until it needed to be replaced.
The reason I purchased it was because its an old proven design. It has been in use for repair of tubeless tires for over 50 years. Its what we used to repair tubeless tires in the 60's. It's still a viable repair system.
learned something new tonight...dynaplug...Big holes - sticky rope. Smaller holes - Dyna Plug. This is not the mushroom head type plugs that fail, I've used dynaplugs on bike, lawn tractors, cars - over 20+ times, no failures. http://www.dynaplug.com/
