Was outside doing a little servicing on the wing today. Oil/filter changed, clutch fluid change and tomorrow engine coolant and brake fluid change. But anyway on to my question.
While the lower cowl is off I decided to pull the toe warmer lever and low and behold the doors wouldn't open. I suspect the cable is corroded at the door end. Upper cable down to where it breaks out to each door is fine. The cables to each door don't appear to be moving and releasing the doors. Checked our sponsors parts IPB and that doesn't show much in the way of detail.
Anyone else had this type of problem and know of an easy and quick fix.
By the way this is an 07 level 3 bike.
Thanks in advance.
Chuck Gunter
Thanks in advance.
Chuck Gunter
