Every fall -- consistently -- as the temps start to drop, shifting becomes difficult on my '05 until I flush and change the clutch fluid. That's usually 10 - 15K miles between servicing. The bleeder valve is always slightly "damp" with fluid which could be left over from the previous year's change, but I'm guessing not really -- the valve surely seeps or weeps fluid, eventually allowing enough air to get into the line to cause a problem.
Servicing (with fresh Honda brand h-fluid) always results in a like-new feeling clutch.
I've never torqued a bleeder valve. I just "snug" them up pretty good, which tells you nothing, I know. But none of my brake bleeder valves weep or seep fluid -- on this Wing or my previous bikes.
So my questions: does anyone really torque a bleeder valve? Would the clutch bleeder valve be more prone to leak due to the constant heat from the engine? I suppose the bleeder valve could be slightly defective from the factory? Why would cooler weather cause this problem to become evident?
Thanks for any feedback.
