1 - 14 of 14 Posts
Thank you for the video and details. So fatigue will take its told over time... the only real solution is a stainless steel spindle to replace the aluminum spindle that is there...
EDIT: LOL you mentioned that at 17:25... I had not finished watching the video when I made the comment.
That seems to be quite a weakness in the original design.
If you replace the spindle assembly with stainless, how do you keep the stainless from corroding the surrounding aluminum? Are they separated somehow?
Reactions: Max McAllister
Discussion Starter #4
We should have a direct replacement part available in about a week.
The spindle only touches the hardened steel inner bearing races. It does not touch the frame.
I haven't watched the video, but just looking at the topic header this appears to be a huge liability and recall issue for Honda.
From what I understand from Max's information and Honda's own service bulletin GL1800 #23 this is unique to the 2018 models only?
Way less than that.... it’s unique to 2018’s with confirned loose steering.
From the Bullitin:
”Only 2018 GL1800 model motorcycles with a confirmed loose handlebar are affected by this bulletin.”
You'd need to choose your grade of stainless carefully, stainless steel is not particularly good at cyclic loading. I'd be using a piece of tool steel.
Have you considered using aluminium? I hear that's what the Brits use instead of aluminum...
1 - 14 of 14 Posts
