I have a non-tour bike. I would like to add a Bluetooth tpms sensor that displays my tire pressure (such as a FOBO. Although my preference is the Cyclops Adventure Sports tpms sensor...same Bluetooth concept though).
Anyway, how is the stock tpms mounted in the rim? I think it’s attached to the rim vs inside the valve stem? I am assuming the non-tour tpms mounts the same in the factory rims as the tour but just doesn’t show the display on the dash?
The reason I ask is if I add a secondary tpms sensor for the fobo/my stand alone tpms monitor, those sensors connect to the valve stem. I like to replace my valve stems with metal t-valve stems so that I can leave the secondary tpms sensor in place and still add air to the tire. Will adding a t-valve stem mess up wherever the factory tpms sensor is or is the factory tpms sensor mounted somewhere in the rim out of the way of the valve stem area?
Also, Has anyone come up with a way for a non-tour to display tire pressure on the stock dash? Yes, I know it will flash and illuminate in a low pressure scenario but I would like to see a number value to keep an eye on tire pressures.
