I used these instructions but cannot get the TPMS to read the extra back wheel, tire, and tpms sensor I purchased. Can anyone tell me if the "red" plug referenced here is the "white" plug found in the same location on my 2018 GL1800?
Here are the directions I used with the VT-15 device.
I used a commonly available fork terminal because it fits perfectly in the connector. There is a special Honda tool for this called the Honda SCS Service Connector 07WPZ-0010100 for about $20.
NOTE: You must reset both sensors, first front then rear. If you have replaced one sensor, such as when you use a different wheel on the rear, you still have to rest both sensors.
1. Place the bike on the center stand.
2. Rotate both tires so that the valve stems are at six o'clock.
3. remove the seat.
4. remove the TPMS short connector from the boot. This is a red connector located aft on the left frame rail. Take off the dummy cap to expose the two connector terminals.
5. add air to both tires to put the sensors in programming mode. This requires that the tire pressures be at least 51 psi. I used 55 psi. After adding air, wait for at least 1 minute for the sensors to go into programming mode.
6. place the VT-15 tool next to the front wheel sensor. The order is important here because the TPMS receiver expects the front sensor first. I placed the VT-15 on a block of wood about 1 inch off the ground and within 6 inches of the front sensor.
7. turn on the ignition, then within 15 seconds insert the fork terminal in the short connector.
8. turn on the VT-15 (click left button). The nice thing about the VT-15 is that you don't have to hold the button on, it stays on so you can be standing to look at the TPMS indicator light on the dash.
9. in 3 or 4 seconds the TPMS indicator light should begin blinking at 1 Hz. The front sensor is now registered successfully.
10. within 1 minute point the VT-15 at the rear sensor. The TPMS indicator light will begin to blink at 3 Hz. The rear sensor is now successfully registered.
11. remove the fork terminal from the short connector.
12. turn off the ignition.
You're Done. Now bleed the air pressure down to 36 front/ 41 rear. Put the short connector back in the boot and install seat. Important: Go for a 5 minute ride to get the sensors out of programming mode.
Note: If it doesn’t work leave short in place and ride bike until both TPMS and Air pressure lights reset then remove the short.
3. remove the seat.
