I do have a ride off center stand (maybe a mistake to get this and get rid of the stock center stand, but that's where I am) but I went out this AM and checked the pressure. In a way I am more confused. I have an electric air pump that I can power with a portable battery that I keep in my car. I have been using this to measure the air pressure, then to add air as needed to get it where I want it to be. Generally I want it about 1 to 2 pounds higher than the recommended pressures of 36 and 41. But today, when laying on the ground to hook up this air pump, I also checked the pressure with two different traditional tire pressure gauges. The two were pretty close in readings, generally only 1 to 1.5 lbs different, but both showed several pounds lower than the electronic gauge built into the pump. So maybe I have been keeping my tires way too low but thinking that they were slightly higher than recommended. To get the rear tire to 42 I had to set the pump to 48 psi. I'll now have to see if the TPMS warning comes on during the next few rides. But the low air pressure warning has not come on, which would be a greater concern to me.Thanks for all the good comments.
