Mobil 1® Synthetic Grease
Automotive Grease
Description
Mobil 1 Synthetic Grease is an NLGI No. 2 high-performance grease which combines a synthetic base fluid with a lithium complex soap thickener. The thickener system provides a high dropping point, while additives impart optimum extreme-pressure properties and excellent resistance to water wash, and outstanding protection against rust and corrosion. Mobil 1 Synthetic Grease has excellent structural stability and low-temperature pumpability, making it an outstanding automotive grease.
Application
Mobil 1 Synthetic Grease is recommended for automotive applications at both high and low temperatures. It is particularly suited for applications such as disc brake wheel bearings, ball and steering joints, and universal joints. It will provide outstanding bearing protection under heavy loads at any highway speed, and where moisture or condensation are factors.
Typical Characteristics
Physical characteristics are shownin the table. Values not shown as maximum are typical and may vary slightly.
Product Number 53201-0
NLGI Grade 2
Soap Type Lithium Complex
Structure Smooth; Slight Tack
Color Red
Penetration, ASTM D 217
Worked x 60 strokes
Worked x 10,000 strokes
Worked x 100,000 strokes
280
295
305
Dropping Point, deg. C ( deg. F) 288 (550)
Viscosity of Oil, ASTM D 445
cSt at 40 deg. C
cSt at 100 deg. C
220
23.8
ISO Viscosity Grade 220
Timken OK Load, ASTM D 2509, lb
Four-Ball Wear Test, ASTM D 2266,
Scar Diam, mm
Four-Ball EP, ASTM D 2596, Weld Load, kg
Four-Ball EP, Load Wear Index 45
0.40
250
45
Corrosion Prevention, ASTM D 1743
Emcor/SKF Water Wash Test, IP 220 (modified) Pass
0.0
Water Washout, ASTM D 1264, 79 deg. C (175 deg. F), wt % 6
Advantages
Mobil 1 Synthetic Grease provides the following advantages and benefits:
All-purpose automotive service
Operating range of -37 deg. C (-35 deg. F) to +232 deg. C (+450 deg. F)
Excellent resistance to rust and corrosion
Outstanding structural stability
Excellent wear protection under heavy loads
Good shock loading protection
Excellent resistance to water wash
Outstanding service life
