Well my initial test after bleeding clutch servo in garage and on center stand is a success. I waited for fans to come on and it shifted normal, I will test it tomorrow after I get everything cleared out of garage to move it.
After your test run, take that Slave Cylinder back out and
CLEAN IT... Bleeding it does not even begin to remove all the gunk that collects on the bottom.
Remove the ~Ft long Rod behind it too... as it develope's a small ridge on the forward end; you can clean it and/or Reverse-it upon re-installation.
I just did same on my 1500 this past weekend; used nylon scrub pads to remove the minor corrosion; and replace the rubber seals. I bleed my clutch every 2yrs, and it's been 10yrs since last rebuild.
I also re-assembled (1st time doing this) using "Hydraulic Assembly Lube" on the seals and piston... So far I am
A-M-A-Z-E-D at how much smoother the clutch operates; usually I re-assemble "dry" as that's the condition (apart from brake fluid) that the piston normally operates.
