I would like to hard wire my Zumo 660 bracket to the handle bar with includes wire harness. I have the Harmon DVD's and can't find the DVD that explains how to take off the Tupperware around the gas tank. Can some one HELP. Thanks
Top Shelter
Check Fred's series index for top shelter. With the later models the trick, I believe, is removing the instrument panel before the shelter. Earlier models like mine are a bit different.
Disk 20 was the first one I check, nothing. It started with the tank cover off. Series Index???? What disk is that?
Here you go
Disc 19 (2012 Update)
2012 Intro --- :09
Side Panel R&R --- :16
Tail Light Mod --- :33
Trunk Panel R&R --- :29
GL2 Way --- :07
Mic Mutes --- :02
Disc 20 (2012 Update)
Top Shelter Removal --- :50
Air Filter Access --- :32
Top Shelter Reinstall --- :3
