Sometimes using turn signals or horn itll mute my speakers. Any help would be greatly appriceated. Long time reader first time poster. Gwrra member. Thanks!
I would look for a pinched wire in your left handlebar switch assembly. You didn't say if it was just with a left or right hand turn indication but either one could be shorted to your mute button which goes through the same wire bundle. If you find a pinched wire(s), use a small amount of electrical tape or several coats of liquid tape. Then use extra care in reassembly so you avoid a reoccurance.
Good luck.
Unless it's a external wire in the harness from the left cluster.You are going to be better off finding a replacement cluster on ebay,or swallowing the pill and buy a new cluster from Honda.
The wiring in these clusters doesn't allow for the slightest of room to make a repair unfortunately.Replacement of the cluster is the usual route.
