1 - 14 of 14 Posts
I'm trying to take better care of my new tires and have two simple questions:
1. What is the best/easiest-to-use tire pressure gauge?
2. If you carry an air pump, what kind and how well does it work?
Thanks a bunch.
Ck with harbor freight they have some great little pumps with pressure gauge
There are several digital tire pressure gauges nowadays. I look for gauges large easy to read displays in 1lb increments. One with a rigid extension may be useful for rearing the rear tire.
Slime makes a nice portable pump. Nice and compact with its own little carry case. Hook it to your battery or run it off a circuit with your preference of terminal (SAE, Cigarette, Coax, Powerlet, etc).
Thanks a bunch.
+1 for the Slime Pump. Note that you can Remove it from it's plastic case, and it becomes quite a bit smaller still.
+ 1 for the slime pump as I have had mine for 5 years and used it to top off on a trip last week to just test it as been awhile.
Comes with enough attachments for three bikes and just plain works
Thanks for the feedback.
I'm looking at the Slime pump and wondering where you plug the darned thing in. ;)
Does anyone use a hand or foot pump?
I'm looking at the Slime pump and wondering where you plug the darned thing in...
> I re-wired mine to include Both a Male-cigaratte-adaptor, as well as a pair of Alligator Clamps... Having both enables me to get a Jump (for the pump) from any vehical within reach (in case my battery is dead).
...Does anyone use a hand or foot pump?
> I use a foot pump for daily pressure adjustment, because it's so much faster than hooking up an electric pump.
> On the road though, I use the Slime pump because it's portable.
I carry an old fashion car tire pump. Keep it in my left saddlebag. It is a chore to pump the handle but reliable when needed. But then again, I only use it when needed on the road. At home I use the compressor.
Bob
One of the adapters lets me plug it into the same connector I use for my battery tender. The BT cord is fused and goes directly to the battery, so it works just as well taking electricity out of the battery as putting it in!
+1 on the Slime pump and a tire pressure gauge that is very similar to, but not the same brand as, this one.
I've done some testing on different gauges, and I've found that the digital ones are much more accurate and provide repeatable results. The Accutire brand seem to be about the best bang for the buck. Even their cheaper models are very accurate. I bough six of these and all six display the exact same pressure and are right on the money when checked against a standard.
Amazon.com sells them for $6
Accutire MS-4652B
I use this one at the house its a little big to carry on the bike but i find it to be very accurate compact air com.jpg :roll:
1 - 14 of 14 Posts
