I've found a method to repair, reinforce and fabricate ABS parts for the fairing on the Goldwing or for any motorcycle, RV etc. using this material. The method involves going to your local plastic supplier and purchasing sheets of black ABS plastic. It comes in different thicknesses, 1/16" 3/32", 1/18" or equivalent mil thicknesses. You can usually get varying sizes, 1 sq.ft. up to a full sheet and depending on the shop, they often have scraps that they will sell you very cheap. It comes in smooth and textured, so be sure to get at least one side (the bonding side) that is smooth. Now drop by Home Depot or Lowe's and get some ABS cement, the kind used for ABS drain plumbing. You can now fabricate, reinforce or repair virtually any broken fairing or fairing parts on the bike. Use sheet metal shears to cut the proper size pieces that you need for the repair. Heavier gauges may require a light jig or hand saw. Use a propane torch or heat gun to make and mold bends, custom angles, shapes etc. When heated the ABS bends like rubber and stays in whatever shape you've made as it quickly cools. Recently upon removing the windshield garnish on my ’01 Wing, I noticed that the left tab holding the garnish and allowing for the windshield height to be adjusted, which is secured by a thru-bolt, was broken off. I quickly was able to fabricate a new tab and glue it into place and was back stronger than new in a matter of a few minutes. In the past I repaired a badly cracked trunk on my Venture. These bikes were notorious for this problem. I cut strips of ABS sheeting about 1 inch wide and the length of the crack and then used the ABS cement to "weld" the patches in place If you've used this cement before you know it works the same as PVC cement, it actually chemically melts the surface of the plastic allowing you to weld the parts together. It is an extremely quick and strong repair process so be careful as once you've put the two parts together you will have a difficult time undoing them and once totally cured it will be impossible. The repair on the Venture trunk lasted for years and was still going strong when I sold it. You can use the cement to "paint" and fill the surfaces and parts after the repair to make it look like a factory or custom repair job. The black cement dries to a smooth shiny surface. This worked so well that I started fabricating parts from scratch. Later I bought a 4x8 foot sheet of 1/4 inch ABS and used this method to make a rock shield for the front of my RV tow car that looked better, was lighter and worked as well as the ones being manufactured and sold for over $400--my total cost less than $50. (The down-side was my friends all hounded me to make a custom shield for their RV's) Hope that this information will be of help to someone. Good luck. Larry Long
