Is there a hook up somewhere on a 2007 ABS wing to attach a hose to fill tires in case of emergancy when traveling or do I need to buy a small compressor to carry?
There are no "air shocks" on any stock Goldwing. Goldwing suspensions are spring/hydraulic systems. There may be some aftermarket air shock system, and there might be some rear air shock system on a trike conversion, but I am not aware of any.Is there a hook up somewhere on a 2007 ABS wing to attach a hose to fill tires in case of emergancy when traveling or do I need to buy a small compressor to carry?
the 1500 wing comes from the factory with an air shock on the right side and a spring shock on the left sideThere are no "air shocks" on any stock Goldwing. Goldwing suspensions are spring/hydraulic systems.
In a previous life, my very survival depended on double redundancy.What are the opinions on the CO2 cartridge type pumps? It would seem that they take up less space and you don't have to worry about hooking them up.
Innovations does make a 40g canisters that you use with a screw on valve.it takes a Metric Boatload of those 12 gram disposable CO2 bottles to fill up a flat tire.
