1 - 20 of 41 Posts
I just came from the service dept of my dealer and was told that 6 hours were needed for a valve adjustment on a 15 gl1800 with about 37000 miles. Is that about right
It shouldn't take near that long to just check them and I would be surprised if they were out of spec with that low a mileage. The two GL1800's I have owned were checked at around 60k the first time and neither were out.
Reactions: JoeHall
First time I did it, with the help of Fred's entertainment DVDs, it took 2 hours. The second time it took an hour and a half. When the dealer told me it would cost a minimum $800 or maximum of $1200 depending what they found, I got the DVDs. Best of luck with it. Ride safe and enjoy the ride.
Crabby Bob
Reactions: jlbc212
When I did the first valve adjustment it took well more than six hours, but when I'm working on my own vehicles I'm usually painstakingly slow. Getting the tension off the timing chain on the right side with ABS brakes probably took the most time as I had to make a tool. I also took the time to remove both cam shafts and then measure and record the thickness of each valve shim. This knowledge makes the next valve inspection and adjustment quicker as I'll know exactly what replacement shim is needed if another adjustment is required. I would expect that a certified Honda mechanic at a dealer who does valve adjustments on a regular basis with all the experience and tools should be able to breeze through this job in less than six hours, but maybe that's what the flat rate book calls for. If you have any mechanical experience at all it's not that difficult of a job to do. As Crabbywinger suggested, get Fred's DVD's and do it yourself. It will reward you with tremendous personal satisfaction.
Who knows what the dealer was really quoting... they might be quoting the book flat rate time which includes adjusting the valves. Just checking the valves takes far less time and at most might reveal several valves out of spec - not all 12 of them.
For comparison the book calls for 7.7 hours to do this on a ST1300 but like a GW the valves are rarely out of spec.
Agree that just checking the clearance is not mechanically challenging. But if one has to remove cam(s) and swap shims, it gets quite a bit more demanding in my opinion.
How long should it take
A 32,000 mile service is around 6.0 hours, and they are probably quoting labor on a complete service.
My dealer gave me two quotes, first was for just checking to see if they needed adjustment, second one was if they had to change any shims.
I forget then exact numbers but something like 3 hours for checking and 6 hours to change any shims, they also admitted they rarely have to deep dive and change any shims.
I always take the bike in the bike in the day before and drop it off, so it is stone cold in the morning when the tech stats on the job, then pick it up later when done.
I need to read up on the checking procedure, when I get back to being retired again in I hope a few weeks, maybe I will tackle the checking portion of the job.
Reactions: jlbc212
What happens if the valves gradually go out of spec?
Should I notice something?
My engine runs smooth as silk (knocking on wood) right now.
It's been a while since I watched Fred do his magic on the heads...but...it seemed to me like he went into great detail. I know it wasn't six hours though. I fall asleep in every movie and I was definitely awake the whole time. Maybe changing that disc out in the middle helped out?
Reactions: Red Wing One
My experience and not a recommendation.....
My 2005, I always run full synthetic oil.
I had the valves "shims and buckets" first checked at 36,000 miles. All were within spec.
I later had them checked at 82,000 miles. Still in spec but getting closer to needing attention. Sold with 113,900 miles. Did not have any performance issues, even when riding from the Calif. coast to Rocky Mountain Nat Park and Beartooth Pass Over 11,000 feet and 111,000 miles on the clock.
Valves should be inspected and adjusted when needed. But I was amazed how they performed with all those miles.
Corventure Daev
As with most modern day PGM-FI systems, running poor pretty much means that a part(s) is failing in the system itself. Engines' today almost always start, accelerate, and perform well. However, the engineers say that 5th gens need their valves checked and adjusted every 32k because they wear in 2 places. The first is at their seat. Unfortunately, that wear cannot be seen unless valve work is being done. The other place is in their cam journals. This can easily be seen when the cam covers are removed. It can also be checked by using plastigage.
If the valves are set to center spec, quicker starts, better performance is often noticed. Nothing beats an even amount of air/fuel mixture entering and leaving the combustion chamber.
Clearances get tighter, not looser so you won't hear a ticking warning you that adjustment is overdue. Performance will gradually decline but it will be hard to detect.
Reactions: JoeHall
Thanks!
It may take that time if a shim has to be replaced. The dealer has a special tool that most of us don't to hold the cam in place as we remove the cam shafts to get to the shim. I had checked my valves on my first GL1800 (2001) at the 40,000 mile mark in 2005 and had just one shim needing replacement. So, I ordered the special tool from the dealer and before it came in, a woman ran over my Goldwing and totaled it. Gosh, I loved that bike. The dealer gave me a refund for the tool since it was a Honda Part Number, and had not come in, yet.
1 - 20 of 41 Posts
