1 - 3 of 3 Posts
For those who are interested.I just checked my valves at 34,000 miles and every valve was good except for #5 intake which was .0005 tighter than specs.This is acceptable in my estimation.I will check it again in 20,000 miles.I believe one could go 50 to 60 thousand without ajustment,but I would still check them.You never can tell what they were when it was built.
I hope this helps some of you worry less. A .006 thousands gage went in tight and a .005 gage went in real loose. A word to the wise the valve springs are very light and you could compress them with a bigger gage.If you don't have "THE TOUCH" let someone who does do it for you. I hope this helps some of you.....Jim
I am probably in big trouble, I have 207k on the bike and have never checked the clearance... But it runs good and compression is good !!
JMHO 8)
1 - 3 of 3 Posts
