I have seen reports here of several that were found to be out of spec on the initial check. It seems the early year editions were more prone to that. My '02 had the front right exhaust a bit under spec and two ro three right at minimal spec at initial check. Fred, I think, reported similar findings with his '02 and now SneakySnake recalls his '02 to have similar. Fred and I bith went nuts and "center spec'd" all the lash on each. That is nuts, spec is spec; but some of use are obcessive tinkerers.
IF you find one out of spec, before taking your measurment as gospel, rotate the crank through a few revolutions and check again. Even more imprortant, when you actually replace a shim make sure you remove all th eoil film from the bucket's shim recess and the surface of the stem were the underside of the shim contacts. Honda says to blow it away and those cans of dry air for electronics cleaning are very handy for that. I wipe it with lint free tissue and then blow the surface dry. If you do not do that and your oil is really good oil, your result will beout of spec to the wide side after the engine runs a bit.
Similar to Deputy Dog's inquiry, how many valve checks done after valves were found to be OK on previous check on broken-in engine were later found to need a check. My bet would be (if I were a betting man) very very rare indeed. I have 95,000 miles and next check is 15,000 away.
