I removed my front tire valve cap and immediately could hear air escaping. I tightened the valve core and the air quit escaping, but it wouldn’t take any air unless I loosened the core then tighten it again when I was finished.
When I had the tire installed a month ago, I also had a new Cyclemax valve stem installed.
So do you suppose the core is bad and I just need to put in a new one? Can I remove the core and install a new one without loosing the seal on the wheel?
I can get over my head fairly quickly working on the wing!
Sent from my iPhone using Tapatalk Pro
