I have a new set of black valve covers due in any day now, was curious what the experiences have been from this group on the need to change the gaskets every time the cover is removed.
Are folks installing new gaskets at each valve check? This not just a remove and replace the cover like the valve check, it would of course require removing the old gaskets and moving them to the new covers.
Can the gaskets be safely removed from the cover with out damage, I know they are not that expensive, and certainly do not want a leak, but why change them if they can be swapped over?
Thanks for any input.
