1 - 8 of 8 Posts
There is a 12v plug for accessories behind both the left and right pockets. You could also run a pair of wires directly back to the acccessory terminals in the fuse panel.
Ride safe.
IBTrike, ?? I didn't know there was a 12V rec. behind the right pocket. Is it the same plug type as under the left pocket? Thanks
I tied into my heated grip wiring.
gwlrhfarm, thanks for that link for the 12V connection.
johnocooper said:
I like the one under the left pocket and I use Venco's meter
I also have the Venco meter...pretty slick, although somewhat more expensive than the same meter I've seen w/o the metal frame and w/o the wiring.
1 - 8 of 8 Posts
