While I sit here waiting on Hurricane "Mustang" Sally to knock on my door I thought I would ask before I loose power.
When using WAZE for my GPS I have a hard time hearing it over my headset particularly when music is playing . Changing the "GPS Volume" on the wing doesn't seem to help.
So what is the trick to increasing the volume of the WAZE GPS so I an hear it over the music. I'm sure it is simple but so am I so try to use small words.
Thanks.
Reactions: Bayrec
One of the reasons I like Waze is that I can shut audio instructions off. Indy GW'er gave good advice.
If you dig into the menus deep enough there is a spot for adjusting the volume of various sources of audio. Or you can adjust the source playing by the handlebar switch. Either method works, I get the gross adjustment set via the menus and fine tune it with the handlebar switch.
Waze doesn't come from the bikes GPS, so GPS volume probably isn't the one to change.
Are you sourcing music from the phone or from another device?
Sometimes one might have to remove the app and reinstall it. Don't forget to power off and on.
