Hi all,
I have read that some people have located their XM antenna inside the trunk lids inner liner. I live in NJ and wonder that being further north than some of you if this location could be a problem (the XM satellites are way south – like at the equator if something.).
I have a 2006 and I have the seat, Meter Panel and Top Shelter off the bike (I am doing other things as well) and would like to know the easiest way into the trunk lid liner. Thanks for any help you can offer.
By the way - I didn't know that you could mount the antenna under plastic so I went out to the car this morning and covered the antenna (which is on the roof) with my helmet and the reception did not change.
Still not convinced I took a plastic bucket and put it over my helmet - still no change in reception. So I'm guessing that plastic doesn’t block the signal at all.
But I did note that if I put my hand anywhere over the antenna the signal is lost. I guess I should have gone to engineering school
Thanks, RIDE SAFE
DonNJ
Thanks, RIDE SAFE
DonNJ
