Hi All,
Here is a list of what I have done to my 2018 GW Tour DCT Airbag (in no special order):
2 - inView, the helmet-mounted wireless brake and turn signal light. Too much to tell and I risk getting banned if I do (I own the company).
3 - TailBlazer - tailBlazer | Designed, Developed and Assembled in the USA (kisantech.com) really like it, easy install, great bang for the bucks! It did take some time to get the 2 modules (1 for each side) to fit under the seat.
4 - PathBlazer - pathBlazer | Designed, Developed and Assembled in the USA (kisantech.com) . More great value. But I did have a problem. Essentially, the system modulates the high beams during the day. A light sensor turns this feature off at night. The instruction say drill a 3/8 hole and install the light sensor. Which I did. Next install a grommet (included) around the light sensor and fir it to the hole. Nope. The grommet they supplied was too small. I contacted Kisan and they were apologetic and discovered that their supplier no longer made the right sized bushing. &*%^$$%^@! I now had a 3/8 hole in my upper deck. I found a grommet at Home Depot that did the trick and all is good.
5 - Thinkware M1 Action Cam Thinkware M1 Motorcycle Cam | Dash Cam | Thinkware USA - see pic 1 installed on the front fender. A second cam is installed under the top case. Great quality cam, easy, but time consuming install to hide the wires. It provides ride documentation and security, just in case.
6 - PMD60 - PDM60 | Rowe Electronics (rowe-electronics.com) Easy install, user programmable, makes getting power to accessories really easy.
7 - Trunk and Side Case Lights - Motion Sensor Closet Lights, MOSTON 10 LED Wireless Under Cabinet Lighting with Built-in Rechargeable Battery, Stick-on Anywhere Magnetic Night Lamp for Cupboard Cabinet Kitchen Stairs, 3 Pack - - Amazon.com I installed these with velcro. They work great. They come on with motion and remove easily for charging.
8 - Trunk & Side case carpet liners. They just add a nice touch and keep things in place. Trunk/Saddlebag Carpet Set for 2018+ Gold Wing (wingstuff.com)
9 - Traxxion Seat bolts - smart! Simplifies seat install. Super Seat Bolt Kit for 2018+ Honda Gold Wing - Traxxion Dynamics
10 - Top case organizer - plastic dividers that really help keep things separate and in their place without sacrificing main trunk space -
11 - License plate compartment - a simple, locking box behind your license plate DrySpec Stash Box Lockable License Plate Storage Box - Twisted Throttle
12 - Show Chrome Fuse Block Isolater - Amazon.com: Show Chrome Accessories 13-311 Electronic Fuse Block Accessory Lighting: Automotive - awesome device - gives you brake and turn output as well as keyed and ignition power!
13 - DCT Parking brake interlock. Honda Goldwing / Tour DCT Parking Brake Interlock Harness – Electrical Connection Why doesn't the GW come with this?! PITA install. Not hard, but time consuming. Lots of panels to remove. It prevents you from moving with the parking brake on. Smart!
14 - Helibar Risers. HeliBars® Tour Performance™ handlebar risers for 2018+ Honda GL1800 I am tall and used to adventure style bikes. It improves my riding position. Slow, careful not-to-difficult install.
15 - Traxxion Steering Pin Steering Safety Pin, 2018+ Gold Wing - Traxxion Dynamics - why take a chance? If you're doing Helibar Risers, install is a no-brainer!
16 - Wild Ass Seat Pad. Motorcycle Seat Cushions, Motorcycle Seat, Motorcycle Seat Pad - Wild Ass (wild-ass.com) Well made, air adjustable. It is comfortable and gives me a little rise (the GW sits low compared to my last bike - a BMW R1200 GS Adventure)
17 - Side stand enlarger - Amazon.com: Aluminum Motorcycle Kickstand Side Stand Enlarge Extension for Honda Goldwing GL1800 2018-2020 (Black): Automotive - she's a heavy bike on soft asphalt!
18 - EZPass Skin - hids the ugly white EZpass on a black dash - Amazon.com: EZ SKIN Bundle: Silicone Skin for EZ Pass + Silicone Pad to Cover the Back + Black Interlocking Strips + Alcohol Prep Pad = Discreet Look INSIDE & OUTSIDE Your Car! (Fits EZ Pass Mini, Latest Version): Car Electronics
19 - Dash screen saver - Amazon.com: Coolsheep 2pcs Motorcycle Scratch Cluster Dashboard Protection Screen Instrument Film Protector for Honda Goldwing GL1800 2018 2019 2020: Automotive - Cheap insurance
Simple install.
20 - Grip Puppies - Amazon.com: Grip Puppy Comfort Grips - The Original and the Best!: Automotive - if you have big hands, they make the grips more comfortable. Heat comes through just fine.
21 - Twisted Throttle Denali D7 lights - DENALI D7 2.0 TriOptic LED Light Kit with DataDim Technology (twistedthrottle.com) Simply amazing lights. The lenses provide both fog and distance and are benchmark for aftermarket lighting. I drilled the under-light cover for the second mounting hole and to pass the cable through (which I protected with a grommet)
22 - Firecreek light brackets - Light Brackets - Firecreek Accessories - very nice, very strong. Not cheap, but worth the money for heavy lights. Great support from the company!
23 - Hopnel tank bag - Small, but handy! Amazon.com: Hopnel HG18TP Goldwing Tour Tank Pouch: Automotive
24 - Honda 12V accessory port - 12V Accessory Socket for 2018 Gold Wing (wingstuff.com) - super easy install (once you have the panels off).
25 - Gopldstrike drink holder - Goldstrike Drink Holder (wingstuff.com) - Its there when you need it and the mount can be used for other things (like a phone, etc.)
26 - Fred Harmon s Maintenance videos - Watch Fred Harmon's Maintenance Videos for 2018+ Honda Gold Wing from Angel Ride Videos & WingStuff Online | Vimeo On Demand on Vimeo - simply worth their weight in gold. I couldn't have done all this without them.
27 - Utopia seat backrest - Utopia Driver Backrest for 2018 Gold Wing (wingstuff.com) - nice improvement in comfort and gives the passenger a small storage compartment.
28 - Goldstrike highway pegs - Honda Gold Wing 3-Way Adjustable Highway Peg Mounts | Goldstrike (goldstrike3d.com) I found these to give me the most reach and adjustability without sacrificing lean angle. They are a must for me because I cannot bend my left leg enough to get my foot on the normal peg.
For all of these things, install was easier than I expected. It is intimidating at first, but if you take your time and follow Fred's videos, you'll get through it. It does take planning! If you are taking panels off, what else should you be doing?! Organize and label the pieces you take off. Take pictures of assemblies before you take them apart! Don't be in a hurry. Don't muscle anything! Watch Fred's videos!! (Can't say that enough!)
Next project - (purchased, but not yet installed) Honda top case rack and accessory light, rear fender filler, Denali sound bomb horn replacement and Traxxion tie rod upgrade!
- Tilting Motor Works TRiO front end
- inView wireless helmet-mounted brake and turn signal light
- TailBlazer modulated tail light
- PathBlazer headlight modulator
- M1 DVR front/rear HD Cameras
- PMD60 power module
- Trunk & side case motion sensing lights
- Trunk & side case carpet liners
- Traxxion seat bolts
- ShowChrome fuse block isolator
- Parking brake interlock
- Helibar handlebar risers
- Traxxion steering pin
- Wildass seat pad
- EZpass Skin
- Dash screen protector
- Grip Puppies
- Twisted Throttle D7 Lights
- Firecreek Light brackets
- Hopnel Tank Bag
- 12V accessory port
- Goldstrike drink holder
