I'm trying to install a "flasher" circuit for my headlights on the 2001 GL-1800. Using the Honda Manual, it says to remove the instrument grill first. All fine until I try and disconnect the 4-plex molenix connector that hooks up the three display buttons above the ignition switch. Until you can disconnect the plug, you can't lift the grill off or even up very high (if you have big hands, you have enough room to slide your hand under there but that's about it). I can't get the molinex to unplug - it is the type of molinex that requires that you depress two small "buttons" on either side of the connector to unlock the connector. Is there a tool to do this? Is there an easy way to do this? Is there a better way to access the back of the headlights to plug in the flasher circuit?
Appreciate the help.
Dale
Dale
