when checking tire pressure i am looking for a tempature chart as the weather has been quite warm and checking tires cold is proubly different according to tempatures out side.
AgreeYou may want to check out filling with nitrogen. Your pressure will remain constant and won't need to be checked as often.
Sorry, this tale is simply not true. Nitorgen behaves the same in its pure form as it does in the normal atmospheric mixture form. Pressure of a gas is a linear function of temperature.You may want to check out filling with nitrogen. Your pressure will remain constant and won't need to be checked as often.
A Google search using the following: site:gl1800riders.com/forums tire pressure altitude will show some past threads on the subject. Tire pressure gauge reads about .5psi higher per 1000' increase in elevation.We will be traveling thru Colorado soon. What is the consensus for elevation changes and air pressure?
The OP lives in Las Vegas. He ain't gonna see 68 degrees for a few more months. So, I'm sure he just wanted to know how to check his pressure when "cold" is 90 degrees.Goodness.....some on this forum really like to worry about things they needn't worry about....nonetheless for the record:
Universal gas law
PV = nRt
pressure x volume = number of moles of gas x gas constant x temperature
R = 8.314 joules per degree Kelvin
T is absolute temperature (degrees Kelvin)
As temperature increases so does pressure at constant volume....the more gas the higher the pressure (WOW!)....I am guessing that the tire manufacturers are aware of this amazing scientific fact and have taken it into account when publishing cold tire pressure requirements
AND
I bet they have done all sorts of measurements and stres tests on the tires taking into account lots of variables
For me....I check pressure in the AM.....very, very occassionally I have to add some premium 78% nitrogen blend....this has worked for the last 30 or so years of motorcycling
But the question is, what pressure do you set it to? Do you set it at the actual pressure the manual tells you, or do you adjust for ambient temperature?Goodness.....some on this forum really like to worry about things they needn't worry about....nonetheless for the record:
Universal gas law
PV = nRt
AND
Adjust for actual ambient cold (before running) temperature . 1 psi per 10 degrees F up or down from 68 degrees F (98 degrees ambient before running = plus three psi over your normal cold psi). Then don't touch it all day.But the question is, what pressure do you set it to? Do you set it at the actual pressure the manual tells you, or do you adjust for ambient temperature?
I read all that above, I was trying to get his thoughts as he seemed to simplify it so much.Adjust for actual ambient cold (before running) temperature . 1 psi per 10 degrees F up or down from 68 degrees F (98 degrees ambient before running = plus three psi over your normal cold psi). Then don't touch it all day.
