We have read about recommended tire pressures from the many threads on this board. We know that psi changes with temperature at the rate of 1psi/10deg f. However as altitude increases, atmospheric pressure decreases. For example, atmospheric pressure pushes against the earth at 14.7 pounds per square inch (1 kilogram per square centimeter) at sea level, yet drops to only 10.1 pounds per square inch at 10,000 feet.
AlKnowing this, do we need to calculate/adjust our tire pressure to the conditions as we check them before the ride? Some have stated that tire pressure is acountable for a number of tire problems. I have read that some TPMS do not compensate for altitude, only temperature. A tire pressure gage will read different than some of the TPMS after an altitude change, this information came from a Nissan service bulletin. It stated, for example: a tire inflated to 30psi at sea level @ 70deg f would have 33psi at 5,250' @ 70deg f.
So, for this discussion, at what temperature and altitude do we use for our benckmark for tire pressure? When traveling, do you make pressure adjustments on your pre-ride tire check to the conditions? Should we have a formula for our adjustments or is it all just bunk?
:shrug:
opcorn:
On a recent trip to Colorado, I started out with 40/43 and 80 deg f by my TPMS in my garage in Oklahoma. The second day in Trinidad CO the pressure was lower on the morning check by a couple of pounds. Over the next few days I noticed a decrease in pressure to 35/38 as we climbed higher and were in cooler temps in the morning, no adjustments were made in pressure. We spent 6 days in Colorado and as we decended to lower altitudes and higher temperatures the pressure would increase. After the trip I checked the TPMS and @ 82 deg f the pressures were 38.5/41 in the garage the next morning.
Doug
:shrug:
Doug
